AC power cord to TT: can you hear the difference
0 Members and 1 Guest are viewing this topic. Read 1919 times.
Walterwalter
« on: 30 Apr 2008, 02:40 pm »
Hello everybody! I wonder how many audiophiles can hear the difference in sound with  different AC power cable to the turntable? Share your experience, if you ever tried that.
BobM
Re: AC power cord to TT: can you hear the difference
« Reply #1 on: 30 Apr 2008, 03:43 pm »
I remember a quote from Bob Crump, some years ago, when asked where he suggests the first place to put an upgraded power cable - on the TT motor.
I know I got a minor improvement doing this, but a bigger improvement plugging it into a power conditioner, then a bigger improvement plugging it into a speed controller (which is plugged into the power conditioner now).
Enjoy,
Bob
chosenhandle
« Reply #2 on: 30 Apr 2008, 04:04 pm »
I suppose that if your TT doesn't include some sort of voltage control/speed control circuit, a PC could make a difference...but how much?
twitch54
« Reply #3 on: 30 Apr 2008, 05:58 pm »
if it's an isolated motor on a belt driven TT...... please, someone explain to me how could it make a difference ???, assuming the stock power cord is of competent construction. Please give solid scientific reasoning, not the usual "Audiofool Snake Oil BS" !
Walterwalter
« Reply #4 on: 5 May 2008, 01:33 pm »
Yes, actually it seems illogical for me too, if changing AC cable can make the difference.  I just want to hear other peoples opinion, maybe someone has different experience with that.
Wayner
« Reply #5 on: 5 May 2008, 02:57 pm »
I just can't get into the power cable makes a difference camp. Unless it is undersized, then I can. What does a table motor draw? 20 watts? Sounds like an 18ga. would be fine. OK, 16ga. if you must (that will handle 13 amps).
20 watts/120 volts = .16666 amps.
Wayner  :)
