a mix of Mac/ Windows, using FLAC
0 Members and 1 Guest are viewing this topic. Read 2121 times.
rick57
« on: 30 Apr 2008, 07:19 am »
Hi
(The plan is playing the same lossless files via a mix of Mac/ Windows pcs in 3-4 adjacent rooms, connected via a shared router to a master EHD - a Buffalo NAS).
I was in two minds whether to make the primary music player a Mac or a PC.
MP3Toys for PCs has several nice features, including lyrics search (I think it can be automatic), http://www.mp3toys.net/ and  http://www.mp3toys.net/v25news.html
It supports WMA, OGG, FLAC and M4A.
I’d like to use MP3Toys on one machine - my wife’s (she’d like the interface).
Max for Macs can generate FLAC, AAC, Apple Lossless, Monkey's Audio, WavPack, Speex, AIFF and WAVE.
Play supports FLAC, WavPack, Apple Lossless etc
iTunes: AAC, Apple Lossless, WAV, AIFF, FLAC “in Ogg container”9 http://wiki.hydrogenaudio.org/index.php?title=ITunes).
The only common format is FLAC.
Any reservations or advice about sharing that way, with FLAC?
rick57
Re: a mix of Mac/ Windows, using FLAC
« Reply #1 on: 30 Apr 2008, 09:51 am »
Based on Crimson recommending its interface, Cog http://cogx.org/features.php
& FLAC could be the Mac player . .
Cheers
Crimson
« Reply #2 on: 30 Apr 2008, 10:00 pm »
Cheers
I did?  :scratch:
It's a great player, but I'm a hard core iTunes user because of it's ability to access shares and stream to multiple devices.
rick57
« Reply #3 on: 1 May 2008, 06:36 am »
Hi
Are you saying that Cog and Play can’t share and stream to multiple devices?  :o
Crimson
« Reply #4 on: 1 May 2008, 11:18 am »
Hi
I'm not familiar with Play, but Cog cannot connect to multiple shares simultaneously, nor can it stream to multiple devices.
rick57
« Reply #5 on: 6 May 2008, 01:48 pm »
To clarify:
The aim is to use one Buffalo NAS, and each of 3-4 Mac/ Windows pcs in adjacent rooms to at different times, access that NAS.
Ideally:
 - when using the Windows pcs, they’ll run MP3Toys (recognizing added tags), and
 - the Mac to run iTunes/ Play/ Cog.
Does that sound doable?
Crimson
« Reply #6 on: 7 May 2008, 09:39 am »
You shouldn't have any problems. Just remember to back up!
