Small Speakers for Office-- Proac vs. Spendor vs. NSM vs. Cheaper options....
0 Members and 1 Guest are viewing this topic. Read 7073 times.
sbrtoy
These little guys sound pretty nice, a little pricey but maybe someone has a used pair to part with?
http://www.roleaudio.com/kayak.html
jon_010101
Jon, I *think* our resident Affordable Audio publisher has heard those Aperion's...
On a different note; I am currently evaluating the ELT-525M (almost as we speak). This speaker can do a few things amazingly well.  What kind of music do you plan on listening to ?
Oh, I listen to everything.  Definitely NPR... indie rock... jazz... folk... classical... electronica... and whatever my iTunes shuffle digs up.
I am just concerned that I don't have enough space for the 525s and their rear port.  Ideally, I'd like to slide these right up against my rear wall / desk behind me.  At the same time, it may be possible for me to use a Mapleshade-style tilt stand to aim them at the back of my head.  But I don't want my co-workers to think I'm (too) insane.   :wink:
SBR: If I can find a used pair in my price range, the Kayaks look verrry nice.
doug s.
  • makin' music
shameless plug:
custom made, upgraded components/cabinet, dillon acoustics ego kit speakers:
read about it here, w/focal 5W4252 midwoof & hiquphon owii tweet:
http://zalytron.com/Schematics/ego.doc
the kit (stock) is awailable from zalytron, & costs $890, including cabinets.
http://zalytron.com/HiqKits.htm
i will sell mine for quite a lot less, & they're awreddy built, w/upgrades - internal sound dampening, premium wood (the front is honduran rosewood), premium binding posts, auricaps & audience wiring...  and yes, they do sound great!  i yust have way too many speakers presently...
thanks,
doug s.
ps - they weigh a lot for their size!   8)
jon_010101
Hi Doug, Those are very pretty!  Great finish!
I'm just curious, it looks like there is some gap around the woofer?  PM me if you have a price in mind, I'd definitely put it on my list to consider.
Another weird possibility (if this might work) would be Magnepan MMG-Ws for my wall in front of the desk.  I'm pretty sure I can get away with that.  I won't be exceeding 65dB, so my tube amp should be just fine driving them 8)
Those Intimus 4B speakers have a bass (more like mid-bass) cut off of 100 - 120 Hz!
doug s.
  • makin' music
yes, the builder cut the cabinets a bit too large, & stuffed the gaps with some sort of pliable material.  it looks ok, & works fine.  check your pm for more info.   :wink:
not sure how maggies would like being flat against a wall, even for non-critical listening...
doug s.
jon_010101
doug s.
Ah, those maggies are specifically wall-mount, so I expect they'd do okay ... but it might be a psychedelic experience working in the nearfield of a pair of planar speakers  :lol:
JP78
i'd like to throw a vote out there for audioengine5 monitors.  sure they're powered...but man do these little guys sound really, really good.  they're extremely cheap too...swap out that tubed int for a tubed pre (or dac if it's coming out the computer) and you'll be in heaven.
http://www.macobserver.com/review/2007/03/29.1.shtml
i'm listening with a pair right now...i alternate between these and sennheiser 650's...surprisingly i don't feel that disappointment taking off the cans and turning on these little guys that i thought i would.  i have the volume controlled via computer, and they're being driven through a cal alpha d/a straight into the audioengine speakers.  it's really, really surprising how such a reasonably priced solution can sound so good.
or, if you're firm on passive speakers, i'd like to also recommend dynaudio contour 1.1's.  they're small, have clean bass...though i am partial to the dynaudio house sound in general (i love and have owned at some point the special 25, confidence 3, confidence 5).  i saw a pair on agon sold for 800usd (obo) used.
well, happy hunting ;).
