shorting vs non-shorting RCA shielding cap - what's the theory?
0 Members and 1 Guest are viewing this topic. Read 5184 times.
AliG
Can anyone tell me why one would want to use a shorting RCA cap like these:
And what's the advantage of a non-shorting caps like these sold by Cardas?
Housteau
I know that some manufactures do recommend using them on some amps and pre-amps.
Haoleb
From a technical standpoint, At least in my opinion shorting plugs would be better for the fact that they will ground all wires and traces leading up to the selector relays or switches on a preamp which is reducing possible interference from those areas. For obvious reasons you woudlnt want to use them on outputs. They are good to use on unused inputs on preamps just to be sure that you have the quietest circuitry possible. Most preamps come with them for use on tape inputs standard. Although if you dont want to spend big bucks for fancy ones you can get a bunch of those cheap rca cables that come free with most equipment. Lop the ends off and leave maybe half an inch of wire sticking out of the plug then solder the wires together.
Im not sure what advantage the cardas type without the center pin has.  This is taken from their website...
Cardas RCA Caps fit over unused female RCA connectors in your system to eliminate EMI and RF noise absorption. Unlike traditional shorting plugs, these caps do not short the inputs (many pre amps do not like having their inputs shorted). Another difference is Cardas RCA Caps completely cover the RCA input with a solid shield of nickel and brass to prevent both EMI and RFI from entering the chassis through the RCA dielectric. This is a more elegant and probably more effective solution than either shorting plugs or wrapping the plug in aluminum foil. Our caps also protect the RCA from dust and corrosion.
I dont see why they claim that "many preamps dont like having their inputs shorted" Since most high quality preamps use relays it wouldnt make a bit of difference Unless of course the input was switched to the one that is shorted. That could possibly present a problem.
Ethan Winer
  • Audio expert
That makes no sense to me either. All gear these days uses the protocol of low output impedance and high input impedance. So inputs that are connected and active are essentially shorted from the preamp's perspective anyway.
--Ethan
miklorsmith
Just for clarity, shorting caps should never be used on preamp outputs, only inputs.  I know you guys all know this, but just in case an outside observer gets crazy notions . . .
