Panasonic battery-powered antistatic gun
0 Members and 1 Guest are viewing this topic. Read 1181 times.
wallace
« on: 22 Apr 2008, 05:20 pm »
Dont suppose any of you have this old artifact.
Wallace requires instructions to use.
Also, since we are on proper proceedure:
Those ubiquitous 70s Discwasher (D4) brushes with the walnut handles: just for wet cleaning??
Whats proceedure?
Any decent, or just toys that rub the dirt back in?
Wayner
Re: Panasonic battery-powered antistatic gun
« Reply #1 on: 22 Apr 2008, 05:53 pm »
I use the Discwasher brush all the time. I do use a wet spray (4 to 1 mixture of H2O and 99% isopropyl alcohol) in a spray bottle. A couple of sprays on the brush, then wipe the dust off the LP. I've used this trick for most of my life. Records are as clean as can be.
Wayner
wallace
« Reply #2 on: 22 Apr 2008, 06:07 pm »
Wallace understands you have to rock that brush as you use it. (Thats why the pile-wotsit surface is curved  - moreso, if you ever saw it, the Realistic version of the brush.)
You spread your cleaning solution/scrub  using one  end of the pile, then you tilt back and remove it with the dry (unused) end.
Wallace has reservations about this method of cleaning.
Seems that -without suction - your just merely rearranging/shifting residue/grit/mold.
