Computer Blu-Ray & Square Circle?
0 Members and 1 Guest are viewing this topic. Read 1186 times.
Daryl
« on: 21 Apr 2008, 07:02 pm »
I couldn't find 'Square Circle' on the circles list (I may be blind though).
I have been contemplating sourcing my A/V from my computer and had some questions.
First can you get fast Blu-Ray load/play performance from a computer the way that PS3 has fast performance because it is a game machine and has a fast disk drive, CPU and GPU?
I recently got 2gb of 667Mhz dual channel DDR and a Core 2 duo 2.66Ghz (E6700).
I would need to change MB as well to go Blu-Ray and have my eye on a $95 Biostar with onboard HDMI and overclocking ability (looks like I could run my E6700 at 3.33Ghz and 1:1 bus/memory clock).
I wonder can computers load/play Blu-Ray faster than PS3?
Also are all the software/drivers ready for full decoding of all the new HD audio codecs?
« Last Edit: 21 Apr 2008, 07:22 pm by Daryl »
Woodsea
Re: Computer Blu-Ray & Square Circle?
« Reply #1 on: 21 Apr 2008, 07:35 pm »
I hate to point you elsewhere, but I am not planning on doing the same thing myself until later this summer.  I just can't get parts where I live now, in a timely fashion.  But, your best bet would be right here http://www.avsforum.com/avs-vb/showthread.php?t=940972 for most if not all your answers.  Good luck, and keep us informed.
samplesj
« Reply #2 on: 21 Apr 2008, 07:36 pm »
No HDMI sound so you're either going to have to use 7.1 analog outputs or mangle the lossless audio.
Otherwise it works fine.  I'm still using a ps3 for the main HT, but I've got a computer playing blu in the den (only 2 channel though).
Jeremy
Daryl
« Reply #3 on: 22 Apr 2008, 02:00 am »
Thanks Woodsea,
I might join that forum and let them school me about HTPC.
And...
Thanks Samples,
I was thinking a hi-spec USB or wi-fi sound card, internal would be fine if it has suitable filtration of noise from the computer supply.
« Last Edit: 22 Apr 2008, 10:13 pm by Daryl »
