Soundsmith: a new/old phono cartridge
0 Members and 1 Guest are viewing this topic. Read 2311 times.
ohenry
« on: 18 Apr 2008, 03:16 am »
Here's a preliminary report of my Soundsmith refurbished cartridge for those that are curious about their service and results.  The cartridge isn't broken-in yet, but there are some obvious things to share.
I sent my worn out Adcom SXC-VDH cartridge to the Soundsmith to perform the level 3 service where they installed a ruby cantilever which holds a nude "optimized contour" contact line diamond.  For those not familiar, this was Adcom's best cart back in the day: high-output (a little over 2 mv), moving coil, and sapphire cantilever.
The cartridge doesn't have scores of hours on it, but it is already making me happy.  It does the stable 3-D imaging tricks extremely well.  The highs are extended and smooth.  Detail retrieval is very impressive and tracking complex passages is effortless.  Drum and horn tracks reveal cleanliness, authority and speed contributing to realism.  I'm discovering many nuances in some old, familiar lp's that I've been missing.  This refurbished cartridge is generally more refined and agile than when it was stock, but still maintains its basic original character.
The tone seems subtly thin at times, although the low bass notes are being reproduced.  I don't expect that it will ever carry the weight of my Grado Platinum (the anvil), but time will tell if it becomes a little more filled out.
I feel that the cartridge will be a keeper and is already performing above it's cost.  The guys at Soundsmith were nice and did a masterful job renewing my cartridge.  :thumb:
Nels Ferre
Re: Soundsmith: a new/old phono cartridge
« Reply #1 on: 18 Apr 2008, 11:04 am »
They did the same surgery to my Dynavector DV20XH.  I am a happy camper here as well.
woodsyi
« Reply #2 on: 18 Apr 2008, 11:39 am »
How long did it take to get your cart back?  I have a ZYX Airy 3 in for retipping.
ohenry
« Reply #3 on: 18 Apr 2008, 11:44 am »
Well... I told them I wasn't in a hurry, and they believed me.  :oops:   It took about four months.  I'd think that "normal" transactions would take much less time.  I wasn't concerned since I had another cartridge that I liked.
woodsyi
« Reply #4 on: 18 Apr 2008, 12:23 pm »
Oops. I guess I can expect the same time frame since I told them the same thing.   It' fine with me.  :wink:  My question is why did you change the cantilever?  I was told that my boron cantilever on the Airy may be saved.  The less I disturb the original mechanism the better is what I am thinking.  What did Peter say about your mod?
ohenry
« Reply #5 on: 18 Apr 2008, 10:26 pm »
... My question is why did you change the cantilever?  I was told that my boron cantilever on the Airy may be saved.  The less I disturb the original mechanism the better is what I am thinking.  What did Peter say about your mod?
I didn't discuss the repair with Peter.  I just sent it in and told them to refurbish as if it were his.  The web site does state that it's often less costly to replace the cantilever and diamond than sticking a new rock in the existing cantilever.  After thinking about it, it would seem simpler to replace the cantilever/diamond with a pre-fabricated assembly.
