5V4G replacement for 54R4???
0 Members and 1 Guest are viewing this topic. Read 3051 times.
tiofelon
« on: 17 Apr 2008, 03:12 pm »
Hello, regarding the NORH SE9 I just came across a vintage 5V4G rectifier tube in pretty good shape and I am wondering if I can replace it for the 5AR4 sovtek stock tube. I understand that both tubes do no have the same specs, so I do not want to srew things up until I know is safe to swap the tubes. Any help out there? Thanks in advace. Leon.
jqp
Re: 5V4G replacement for 54R4???
« Reply #1 on: 18 Apr 2008, 01:52 am »
I won't advise you except to say it is good to ask for this advice
Hopefully someone with nohr tube product experience will be able to help you out soon
tiofelon
« Reply #2 on: 21 Apr 2008, 08:37 pm »
Ok. So I got an e-mail from Youths and she says yes! go for it! Then I got another e-mail from Mr. Barnes and he says No! ask the tube manufacturer. So I still right where I started! Any others have some advice??
bricktop
  • performus measurementus
    • My Website
« Reply #3 on: 21 Apr 2008, 09:22 pm »
I'd say no, unless you are absolutely sure the 5AR4 is being babied in it's application.  5V4G has about 150% the voltage drop of 5AR4 at similar currents, so anode dissipation may be too much for it.  Voltage ratings for the 5AR4 are a tad higher, but that isn't likely the main concern in most applications...
