To date, all the two channel musical product you buy (with some exceptions of course), are mixed down using pan pots which utterly destroy the localization parametric known as Inter-aural Time Delay, ITD. This is done primarily to keep the two channel product backwards compatable with mono.
We had a fun discussion about this a while back.
When using 2 mics to record stereo, you adjust the spacing of the mics to adjust for mono compatibility. If the spacing is creating a time related out of phase, no amount of panning is going to save your butt. Mono compatibility was much more important years ago, as some records were done in mono, TV's used to be in mono, and AM radio was mono.
The typical (ubiquitous) X/Y stereo mic configuration has one mic capsule (diaphragm) right over the other one. The angles that the diaphragms pointing forward are set usually aimed 45 deg. off center to make a 90 deg, included angle. Essentially the reverse of an equilateral speaker playback setup. The angle can be increased to up to 135 deg. included angle, but beyond that, the image can get a little bizarre.
The general rule is the 3:1 rule when using more than one mic, and combining signals. If you have one mic 1' away from a source, then the second mic should be at least 3' away if you are to combine the two signals and maintain mono compatibility.
If ITD were introduced, or even maintained, the mono result would be heavily combed and rather distorted.
It could be, but not always. Sometimes, it can quite good in mono. It can be hit or miss. If you spent a lot of time on experimenting, you could definitely get it better, but nowadays, it's a pretty moot point. I do check for phase in mono when setting up stereo mics, but it's more about habit than anything else.
There are a number of "ambient" stereo miking techniques, and you can use mics with different polar pickup patterns. The X/Y is the one I prefer, and baffled X/Y can be freakishly realistic in stereo. The other types (spaced pair, Blumlein, M+S etc..), I consider more artful than precise.
This is where the "art" in recording comes into play. Because it's based mostly on experimenting.
I fyou want to know why recordings are all over the map, in terms of sound, it's simply because the first rule of recording is "
there are no rules".
Are they taking any more applicants in the "jneutron" club?
Is there a hazing ritual?
Cheers
