Klaus, amp question, but... not about my stratos.
0 Members and 1 Guest are viewing this topic. Read 1827 times.
ton1313
« on: 15 Oct 2003, 12:47 am »
Klaus,
I am using my Stratos for 2 ch duty, & I just hooked up a new amp for center,suround, & sub duty. A Citation 5.1 4 channel @ 100w. Now I am noticing a slight "POP" from these speakers when selecting a different input, & also when selecting a chanel from dish network. It seems to happen momentarily when the RDC-7 locks onto an audio signal. The "POP" is not noticable from my main speakers which are driven by the Odyssey.
The Citation is a better amp than my previous Carver AV-505, it is much better at resolving low level detail. Maybe this "POP" was there all along, but the Carver was not revealing it.
Any Idea what would cause this? If there are steps to take to fix it?
klaus@odyssey
« Reply #1 on: 15 Oct 2003, 07:50 am »
Sounds like an impedence match problem or a switch problem.  It might sound stupid,  but if the pop is indeed slight,  and doesn't jeopardize your speakers (judgement call on your side),  then I'd just live with it.
This is in the electronics,  and has nothing to do with any environmental doings.
Late,
Klaus
ton1313
« Reply #2 on: 15 Oct 2003, 10:52 am »
I appreciate your help, Thanks Again
ton1313
« Reply #3 on: 16 Oct 2003, 01:20 am »
FYI
The output sensitivity on my pre amp is 470 ohms & the input sensitivity on the amp is 22K Ohms. Is this where my problem is?
Todd
warnerwh
« Reply #4 on: 16 Oct 2003, 03:06 am »
input and output impedances you have should be fine.
