0 Members and 1 Guest are viewing this topic. Read 7054 times.
...People say floorstanders have higher dynamic range and a "fuller" sound that even a subwoofer can't make up for when used with bookshelves. Will SSR, as a big "bookshelf" with a powerful woofer, be a subject to that rule or does it approach a floorstander?
if you are looking for full range bass impact just make sure you pair with a good sub and spend plenty of time getting the integration right.
Just finished assembling another one of my SSR speakers. I only have a monoblock in here, the rest of my amps still sit and the cold, and its unsafe to use them too soon after that.. But even a single speaker sitting on floor sounds amazing - crystal clean, powerful and smooth. It can produce scary bass without a sub too.
