0 Members and 1 Guest are viewing this topic. Read 3874 times.
You know, I think I can listen louder cause the sound is cleaner! Think my room is ringing less. I hate badly compressed records, don't you?
I guess I should chime in too. Bryan and Glenn from GIK were very helpful and very easy to work with. Even with upgraded fabrics which did add considerably to the stock fabric prices, it was pretty painle$$, and we bought 11 panels. Here's a fuzzy pic of the front wall, and there are panels at the reflection points on the side walls and there is one on the side wall in the back corner. With doors and stairs and built-ins, there is no way to put any on the back wall, but I don't hear a problem there.
