Options for an external power supply for Transporter?
0 Members and 1 Guest are viewing this topic. Read 2060 times.
yooper
If one is available, can anyone recommend an external power supply for the Transporter?  If you have one, do you feel (subjective, I know) it was money well spent?
Mark
ted_b
Re: Options for an external power supply for Transporter?
« Reply #1 on: 12 Apr 2008, 02:38 am »
No one, to my knowledge, has created an external power supply for the Transporter; even Dan's Modwright Transporter uses an internal PS.  It's own stock PS ain't bad, unlike the SB3 wallwart (of which there are quite a few very good external 3rd party ones).
denjo
« Reply #2 on: 12 Apr 2008, 02:39 am »
Bet you Paul Hynes can build one!
some young guy
« Reply #3 on: 12 Apr 2008, 03:01 am »
APL Hi Fi uses an all-linear, low noise R-Core power supply for the Duet. It's quite an improvement over the stock switching PS.
tanchiro58
« Reply #4 on: 12 Apr 2008, 06:05 am »
Mark
If you can build yourself a Felix+stock switching PS for your Transporter that would be the better one or you can get a better quality switching PS with Felix that will be the best one ever. I am ready to build one for my Duet.
