class project two way system
0 Members and 1 Guest are viewing this topic. Read 1612 times.
ltaylor
« on: 10 Apr 2008, 03:40 am »
looking for some ideas for box design  wondering if insulation is necessary on the inside or how much to ventilation is necessary also  I'm using a a set of m-130 woofers and don't know what kind of tweeter any help would be great also have to come up with a crossover don't even really no were to begin on that. I  am looking for any kind help
thanks
DeanSheen
Re: class project two way system
« Reply #1 on: 10 Apr 2008, 04:05 am »
S Clark
« Reply #2 on: 10 Apr 2008, 04:37 am »
The M-130 is very forgiving and easy to work with.  Most tweeters with efficiencies of 86-91 dB's should work.  Your crossover will depend on your choice of tweeter and its frequency response curve.
