0 Members and 2 Guests are viewing this topic. Read 4574 times.
Can we somehow connect two separate HD enclosures by firewire and have the Mac OSX/iTunes and SC 7 see them as one library?
QuoteCan we somehow connect two separate HD enclosures by firewire and have the Mac OSX/iTunes and SC 7 see them as one library?WRT iTunes: Fill one drive up with tunes in the normal fashion. Once full, change the path to the second drive but do not consolidate. iTunes will then retain the paths for all tunes on the first drive and all rips will go to the second creating a single virtual library.
Now I do wonder what happens when one has to transfer a library spread across multiple external drives to a new computer which usually requires the Consolidate Library command? Oh well, we'll cross that bridge when it comes.
Would this same concept work on 2 USB drives on an iTunes for Windows setup?
QuoteNow I do wonder what happens when one has to transfer a library spread across multiple external drives to a new computer which usually requires the Consolidate Library command? Oh well, we'll cross that bridge when it comes.You can transfer multiple drives. Hook up the first, point to it, add to library. Switch paths to the second and do the same without consolidating. All iTunes will do on the new computer is rebuild the library database file. You could then add a third larger drive and consolidate the two smaller drives to it.
Quote from: Crimson on 7 Apr 2008, 03:45 pmQuoteCan we somehow connect two separate HD enclosures by firewire and have the Mac OSX/iTunes and SC 7 see them as one library?WRT iTunes: Fill one drive up with tunes in the normal fashion. Once full, change the path to the second drive but do not consolidate. iTunes will then retain the paths for all tunes on the first drive and all rips will go to the second creating a single virtual library.Thanks Crimson and low.pfile for the great news and field testing! I like the idea of having a couple quiet OWC drives connected by firewire to my Mac Mini, instead of a NAS. It's cool we can daisy chain drives as our library outstrips our first drive's capacity. I'll probably get a second striped 2 TB OWC combo drive as a back-up, but only power it up sporadically as I need to back up, to keep the drive noise down to a dull roar. I'm foggy on how iTunes and Slimserver knows to look into the first drive for our library after we change the path to the second drive for new rips. What would break the implied path to the first drive, a temporary removal of the drive?Rob
Thanks loads, guys. Awesome feedback. Crimson, I want to thank you especially for all your incredibly generous, helpful guidance on this circle. It is a wonderful resource and comfort to have this Mac-oriented expertise for our iTunes/ Slim libraries. Rob
I just bought a new HD and hooked it up to my powerbook. I dragged my iTunes music folder from my old HD over to the new drive -- I intend to use the new drive as my active drive and move the one I was using to back-up status. When I switched the path, through iTunes preferences, to the new drive it went through it usual routine of re-indexing (or whatever it is called). After that, when I selected a song to play it would not play. So, I did the old "drag and drop" of the iTunes folder into the Music icon in the upper left, which caused iTunes to commense populating my library with the music files from the new drive. Now I have two copies of everything in my library and the first of each copy has the shadow exclamation point next to it (because there is really only one file, but there are two entries in my iTunes menu). This is a pain to work with because I have to select a specific song to get the album to start playing. How can I get rid of all the duplicates? Is this where I would consolidate?
