Odyssey in my system.....
0 Members and 1 Guest are viewing this topic. Read 1652 times.
Christof
« on: 5 Apr 2008, 07:41 pm »
I've spent the past 6 mos completely revamping my 2ch system and thought I owed Klaus a short review of my findings so far.  There have been many changes to my system including new speakers, I went from SP Tech Timepiece 2.1's (wonderful but too small for my big room) to a big custom pair of 3-way speakers from Rick Craig at Selah, that I call TS-3's...a collaboration between Terrawood & Selah.   I upgraded my Khartago amplifiers to Dual Mono's to power the woofers and Symphonic Line RG1 to power the mid/tweeter circuit.  I also switched pre's going from using an Electrocompainet passive to a Candela.  To stay true to the copper system I decided to use the same Groneberg Premium wiring that Klaus used in the Dual Mono's, RG1 and Candela.  Groneberg serves as internal hook-up wire in my speakers, speaker wires and IC's.  So there it is, short of the speakers and USB cable this is a 100% Odyssey based system.
The sound thus far is wonderful.  Because I've made so many changes to my 2-ch system I do not really have any way to give a comparative review.  I have switched a Promiteus TVC preamp in and out of this new system which gave me a a little idea about the two preamps.  The minimalist TVC, as far as I can tell,  adds nothing to the sound, I really enjoy it for that very reason.  The Candela sounds just a tad more "full" or "smooth" to my ears.  A better way of putting it is the TVC is very matter of fact.  When coupled with components that have a bit of an "edge" the TVC does nothing to the edgy sound while the Candela seems to ease the harshness just a little.  I attribute the round full sound of the Candela to the tubes.  I do wish I would have had both the Candela and TVC when I owned the non forgiving SP Tech Timepiece 2.1's.
Both the Dual Mono's and Symphonic Line RG1 are a healthy step up from the Khartago's in terms of juice.  Both amps are dead quiet and I hear no transformer hum whatsoever, this was also true with my Khartago amps.
As time passes and I develop a good sense/memory of how this Odyssey system sounds together with the Selah speakers, I will begin to switch components and wires in and out and post my findings.  Until then I must give a hats-off to Klaus and thank him for offering these first class products and for doing so at the price level he does, amazing.
Chris
« Last Edit: 6 Apr 2008, 12:08 am by Christof »
Airborn
Re: Odyssey in my system.....
« Reply #1 on: 6 Apr 2008, 05:35 am »
Hey, Chris, congrats on the great new system.   :thumb:  As a beneficiary of your upgraditis by getting one of your Khartagos, let me be the first to congratulate you on your Symphonic Line and Dual Mono Amps.  BTW, I am also getting itchy to try Klaus' Monos, so I don't think I am far behind in the upgrade path for the Odyssey amps.  I think I'll be calling Klaus soon. :D  Please post some pics of that loft fully finished with the Dual Monos and the Symphonic Line in place.   :drums:
All the best,
