0 Members and 1 Guest are viewing this topic. Read 6931 times.
So I was procrastinating () by evaluating my meager setup (a righteous task irrespective of time or other pressures!) and realized that theres a question my engineering brain has not and cannot resolve. Intuitively, the answer to this question should be grounded in sound physics (, sorry ).How far apart should speakers generally be at a listening distance of about six or seven feet on the perpendicular?The reason I ask is that right now, when I listen, I've noticed that if the speakers are 8 to 9 ft, they disappear, any closer together and my ears can place where they are. Am I sitting too close? Intuition would have it that the further apart the speakers are, the wider the resulting soundstage, is this true? I mean, as w tends to zero, the sound becomes a single point source, and as w tends to infinity their sound approaches two point sources, but in a real-world, residential scale, for a given set of speakers is there a range at which one often realizes the greatest soundstage width? Again, intuitively, this depends on the room size, but assume a regular room, 15' x 17' say of which only a 10' x 10' footprint is available. What kind of spacing should I be considering?Thanks much!!!
I would say the Cardas set up is a good general start, but it is worth knowing that recordings are mixed and mastered with the speakers and listener in an equilateral triangle,
