Why MTM?
0 Members and 1 Guest are viewing this topic. Read 1204 times.
martyo
Why MTM?
« on: 3 Apr 2008, 02:05 pm »
What are the advantages of an MTM design?
Imperial
  • Love keeps us in the air, when we ought to fall.
Re: Why MTM?
« Reply #1 on: 3 Apr 2008, 02:35 pm »
As opposed to what other type of configuration?
Imperial
martyo
Re: Why MTM?
« Reply #2 on: 3 Apr 2008, 03:11 pm »
A 2-way with 1 tweeter and 1 midrange/midbass, or in a 3-way, instead of WMT.
Are there inherent advantages. For instance a LineSource may do certain things well that a point source doesn't or visa-versa. Cones and domes have wider despersion than ribbons......but ribbons....There's compromise in all designs, I was curious what the pluses of an MTM are. Why use MTM?
BrianM
Re: Why MTM?
« Reply #3 on: 3 Apr 2008, 03:34 pm »
One thing it offers is greater sensitivity than a standard 2-way.  Presumably greater SPL potential, too?
BobM
Re: Why MTM?
« Reply #4 on: 3 Apr 2008, 03:48 pm »
Yes, the sensitivity is better, but the impediance may be lower (8 ohm + 8 ohm in parallel = 4 ohm load). More cone = more air pressure also. In larger rooms where you can sit a little farther away and have the space for an MTM to gel, they sound more like a good point source with a wider sweet spot than TM designs.
Bob
martyo
Re: Why MTM?
« Reply #5 on: 3 Apr 2008, 03:54 pm »
Thanks Brian and Bob.
enjoythemusic
Re: Why MTM?
« Reply #6 on: 3 Apr 2008, 03:59 pm »
As implemented per Joe D'Appolito, you have benefits of a pseudo 'point source' propagation of the sound wave. Some below links may help better explain more precisely the benefit including, as mentioned, possible higher sensitivity:
http://www.htguide.com/forum/showthread.php4?t=14345
http://www.polkaudio.com/forums/archive/index.php/t-32941.html
Apologies of linking to other forums is bad form (pun not intended). It simply saves me time from rewriting what is already available online or plagiarizing other's posts.
