0 Members and 1 Guest are viewing this topic. Read 2208 times.
For multichannel use, usually the entire front wall is dead.
SBIR is the effect of the spherically radiated bass coming off the wall behind the speaker and coming back at you in varying phase with regard to the direct signal depending on frequency and accompanying wavelength. That is going to happen on both sides of the speaker so in that case, it's almost better to have them directly behind.
