Mac Mini to Pace-car through optical out?
0 Members and 1 Guest are viewing this topic. Read 1544 times.
bcretty
« on: 1 Apr 2008, 11:27 pm »
Since the Mac Mini has and optical out can it be connected directly to a pace-car with toslink? Would this surpass the usb offramp as is the case of the AE to pace-car? If so, I might just skip the usb off ramp and get a pace-car. I believe the mac mini is not limited to 44.1 kHz via the optical out. I could be wrong. This seems to be a more viable solution to my needs.
Thanks.
Brian
audioengr
Re: Mac Mini to Pace-car through optical out?
« Reply #1 on: 2 Apr 2008, 04:21 am »
Since the Mac Mini has an optical out can it be connected directly to a pace-car with toslink?
Yes.
44.1 through the Pace-Car to DAC will be slightly better than Off-Ramp direct to DAC.  Anything through Pace-Car is effectively identical whether it started out S/PDIF, AE or USB.
The Off-Ramp performance is almost as good as the Pace-Car, and at much lower cost it will support all sample rates up to 24/96.  To do the same with a Pace-Car requires tuning and two superclocks.  Gets expensive.  I recommend using the Pace-Car primarily for WiFi servers and transports.
Steve N.
bcretty
« Reply #2 on: 2 Apr 2008, 12:19 pm »
Thank you for the clarification. Looks like the off-ramp is definitely the way to go.
Cheers!
Brian
