looking for amp for bipoles
0 Members and 1 Guest are viewing this topic. Read 2934 times.
joschmo
« on: 31 Mar 2008, 10:42 pm »
Hello
I am looking for an amp for my bipoles.  I am thinking about a kingrex and just bought my first tube amp for my headphones.  I like the tube sound but it is too early to tell if I will switch to tubes (but would like some tube recommendations).  My price ranges is around 500 to 700$.  Any info would be most helpful and I would be happy to further elaborate or answer any questions.
Hank Murrow
Re: looking for amp for bipoles
« Reply #1 on: 1 Apr 2008, 04:36 pm »
Why don't you check this site?   http://www.glow-audio.com/glowstuff.html   their amp does five sweet watts, which should be enough for you unless your room is large.  Cheers, Hank
Louis O
« Reply #2 on: 2 Apr 2008, 11:40 pm »
Hi joschmo,
I heard very good comments on both of the amps mentioned. If you go with the SS make sure to run it in 4 ohm mode. If you can find used OTL this would be pretty interesting in 16 ohm mode.
Louis
joschmo
« Reply #3 on: 6 Apr 2008, 10:44 pm »
Thanks for the replies (thought I would get more).  Anyone know where to get used OTL amp and as I have just heard of them and am fascinated can anyone recommend one or where to hear one
Thanks again
rajacat
  • Washington State
« Reply #4 on: 6 Apr 2008, 11:33 pm »
I also have a pair of Omega bipoles and I think that they would be best served by an amp with at least 15 watts per channel. I just think that the 4-1/2" hemps like a lot of headroom. I'm biamping my Omegas with a pair of Trends 10.1 fed by a Mapletree tube preamp. This combo works well at low to medium volume but at very high volume the amps start to overheat. I'm currently awaiting the completion of the restoration and updating of some Heathkit tube monoblocks that put out ~25w/channel. Given your price range a vintage tube amp would be nice but they are somewhat of a crap shoot unless you get one that has been rebuilt by a reputable pro.
Here's one that looks alright.
http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1212358997
This Cary amp looks nice. Too bad its been sold.
http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1212023938
Here's another Dynaco.
http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1212664573
Dynaco SCA35 integrated that would probably be needed to be checked out and upgraded by a tech.
http://cls.audiogon.com/cgi-bin/cls.pl?intatube&1212279097
Good luck,
-Roy
Dmason
« Reply #5 on: 7 Apr 2008, 01:01 am »
Hemp loves the EL84 tube. Stay within that tube in amps and you will succeed, because there is no such thing as a lousy sounding EL84 amp.
Suggestions: Jolida 102B, www.samsaudiolabs.com for rebuilds, Audio Vista, Dynakit 35
You would win large with any of these choices, which are a few, of many.
rajacat
  • Washington State
« Reply #6 on: 7 Apr 2008, 11:58 pm »
Not sure how these sound but they sure look nice and in good condition.
http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1212788134
-Roy
