Needed plasma mount
0 Members and 1 Guest are viewing this topic. Read 2451 times.
JoshK
Needed plasma mount
« on: 31 Mar 2008, 06:23 pm »
I am just wondering if any of you have seen anything like what I am looking for in a plasma mount.  I've not see such a solution if it exists, which is probably doesn't but seems that it should.
My wife has the idea of turning our old chimney into a faux fireplace with gas insert and a mantle to finish it off.  My older plasma was mounted about where the mantle would reside.  I hadn't mounted the newer 58" plasma because of my wife's vision.
The problem is that this puts the plasma up higher than either of us would like.  With all the plasma mounts on the market I've never seen one that articulates downwards, i.e. in the vertical direction rather than just horizontal.
What I'd really love to see is a mount that comes out about 4-6" and drops down at least 16".  But a 58" plasma is a heavy beast, so it'd be ideal if it had some sort of shocks to assist in lifting it back up again.  So in store it could sit up above the fireplace, but when in use it would drop down in front of the fireplace to be eye level.  I can't imagine that this wouldn't have a market.
Anyone ever seen anything like this, custom or retail?
Bob in St. Louis
Re: Needed plasma mount
« Reply #1 on: 1 Apr 2008, 06:44 pm »
This may work depending on how heavy the TV is, and your level of fabrication skills.
"Rockler.com" sells a mechanism that raises and 'swings-up and out' the top of a coffee table. I'm sure with some good old fashion modification, a fellow could make this mount to a wall instead of the base of a table. The addition of automotive hood or rear trunk supports could assist the lifting. These can be purchaced at aftermarket parts stores fairly cheaply based on load rating capability.
This structure:
Turns this:
Into this:
The wieght of the TV would be the deciding factor though.
.......Or, you could hinge the bottom of the TV and allow the top to pivot down. This wouldn't help with overall height, but would make the viewing angle in relation to the screen better.
Bob
Mike Dzurko
« Reply #2 on: 1 Apr 2008, 07:47 pm »
I don't know if any of these might work:
http://www.sanus.com/us/en/products/productCategory/line/visionmount/pcat/fullMotionMounts/
Peerless also come to mind
Wayner
« Reply #3 on: 1 Apr 2008, 08:48 pm »
These guys are suppose to be the Cadillac of the industry.
http://www.chiefmfg.com/
Wayner
Len_Dreyer
« Reply #4 on: 2 Apr 2008, 02:21 am »
I have one of the WMAA18s.  It doesn't articulate vertically as Josh would like.
Mike Dzurko
« Reply #5 on: 2 Apr 2008, 05:37 pm »
I flipped through a couple distributor catalogs last night w/o success. I'd try Google . . .
JoshK
« Reply #6 on: 3 Apr 2008, 07:44 pm »
Thanks for the ideas guys.  I guess I've seen all but Bob's options.  I was looking for the automated lift idea (upside down to give me the vertical travel I am looking for >>8") but with the option to come out from the wall about 6".  I'm sure if I found it I'd scoff at the price.
Bob in St. Louis
« Reply #7 on: 3 Apr 2008, 08:37 pm »
OOOHHHHHhhhhh, You're talking about one of those fancy big city jobbers that the rich folk use to raise their plasmas up from the foot board of their beds, aren't you. But you want one that mounts to the fireplace and tilts down?  :scratch:
Um, don't know man. Never heard of one that's motorized AND does tricks.
That would be DIY in the extreeeeeme!
Bob
JoshK
« Reply #8 on: 4 Apr 2008, 05:08 pm »
Well, it doesn't have to be motorized.  Some sort of hydraulic spring could work to assist lifting.
Bob in St. Louis
« Reply #9 on: 5 Apr 2008, 12:12 am »
Sounds "do-able" depending on how good of a "DIYer" you are.
Kinda like the TV show Monster Garage, but Monster Theater instead.  aa
Bob
JP78
« Reply #10 on: 7 Apr 2008, 04:49 am »
josh, we install motorized mounts very similar to what you describe all the time.
the k2 robotic mount is very nifty, but it doesn't have more than 4-6 inches of drop.  it is, however, very slick to use. i'm guessing a local a/v integrator would probably charge you 1,000usd to have it installed, maybe a bit more since you're in nyc.
http://www.k2mounts.com/x-arm.html
we had auton manufacture us a dual motor custom mounting system to do exactly as you said.  the cost was about 6,000 usd. you can find more info here:
http://www.auton.com/index.html
good luck with your search,
jqp
« Reply #11 on: 8 Apr 2008, 03:20 am »
We have entered the dimension where the mount/installation costs much more than the mounted  :o
JP78
« Reply #12 on: 9 Apr 2008, 02:19 am »
i'm not saying i understand the dimension, but the mounts do stick around through multiple changes to the television.  :wink:
