Would you be worried that 7B-SST were overhauled?
0 Members and 1 Guest are viewing this topic. Read 1814 times.
AnthemAVM
« on: 29 Mar 2008, 06:11 pm »
I have 3 matching units for sale. All 3 units have new boxes & New packaging. 3 silver units that have been overhauled and fully refurbished with all the switches replaced & upgraded.
This sounds fishy to me, like maybe they were 7B-ST upgraded to 7B-SST, your thoughts?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Would you be worried that 7B-SST were overhauled?
« Reply #1 on: 29 Mar 2008, 06:44 pm »
Hi Anthem,
The ST's can not be upgraded to the SST's so that would be an issue if that is what is being said.
If you can get me the serial numbers I can supply you with a history of the amplifiers. My guess is that they are older units that have been repaired and repacked.
james
AnthemAVM
« Reply #2 on: 10 Apr 2008, 04:39 pm »
James,
Thanks the amps numbers are 773715, 774238 and 774239.
« Reply #3 on: 10 Apr 2008, 05:11 pm »
James,
Hi,
These are ST's not SST's.
james
