0 Members and 1 Guest are viewing this topic. Read 6712 times.
By reputation, the 8 inch Supervox field coil should be an excellent choice. You must have young ears to crossover at 14k! Is that a misprint? An 8 inch driver (without whizzer) will start beaming high frequencies around 4k.
Look to the Nomad speaker design here at AC. Woofer is at the floor, mid/tweeter are coaxial. That's the design ideal.
Where have you heard good horn bass? IMO (anything much under 60 Hz) that requires a garage sized concrete structure to develop the size and stiffness needed.
