Cornet up and running again.
0 Members and 1 Guest are viewing this topic. Read 2770 times.
pretzel_logic
« on: 11 Oct 2003, 12:26 pm »
I replaced the tranny in my Cornet yesterday, fired it up with no tubes and didn't blow a fuse.  I had checked the resistance in the secondaries and compared between the blown and new tranny.  Very low resistance in the reds compared to the new one.  I put in the tubes and fired it up again, replaced the rec tube with an NOS GE.  All the tubes lit up so I checked voltages and all were within 2 or 3 volts of the schematic.  Hurray!
Hooked it back up into the system and after letting it warm up for an hour played a couple LP's before the Cubs game started.  Didn't give it a serious listen but it works and sounds wonderful.  Now time to burn in again.
Thanks to all who helped me with this, I learned quite a bit on diagnosis and that always helps.  BTW, I left in the original diodes after comparing them to a new set.  Don't know why the tranny went but hope this one holds up.
Thanks again,
Brian
Braden
« Reply #1 on: 11 Oct 2003, 07:57 pm »
I as well would like to thank everyone for the help they gave me. Yesterday I installed the new transformer and now my Cornet is back to perfect working condition! However, this moring I was excited to put on a record, but the right channel in my CJ MV50 amp wasn't working! The EL34's are lit up, but they are not hot. I have no idea where to start with this problem! This is going to be a whole other ball game, I can tell. When will it stop? I just want to listen to a #@%* record.
 :banghead:
Braden
pretzel_logic
Braden
« Reply #2 on: 11 Oct 2003, 09:55 pm »
Did you check all the connections/interconnects, speaker terminal possibly loose at the amp or speaker?  Do you have any other source to check it with?
Brian
Braden
« Reply #3 on: 11 Oct 2003, 10:21 pm »
Brian,
I tried switching tube, IC's, speaker wire, to no avail. There don't seem to be any loose connections on the amp terminals, plus I had not touched the amp since last night, when it was working fine. There must be something broken in the circuit that lets enough power go the the input/output tubes, but broke the audio connection. Either way I guess I'm going to have to take the board out of the chasis, which means unsolderinga good dozen wires.
Braden
Braden
Why did AudioCircle upgrade to XP?
« Reply #4 on: 12 Oct 2003, 10:35 pm »
Anyways, I figured out the problem with my amp. The plate fuse on one channel was gone, but the LED light didn't come on to let me know that. I guess the circuit allows enough power to allow the pilots to come on in the tubes. The easy test, which I didn't think of at 2am when I was pulling my hair out, is to switch fuses between the channels and see if the problem follows.
Summary: Fuses are beginning to annoy me.
Braden  :lol:
pretzel_logic
Good Thing
« Reply #5 on: 13 Oct 2003, 02:16 am »
Glad you found the problem.  Let's hope both are units keep working but it sounds like just a fluke thing with the tranny's.  My Cornet worked fine last night and sounded even better.
Brian
