IEC cutout for Cornet2
0 Members and 1 Guest are viewing this topic. Read 1486 times.
marchewd
« on: 23 Mar 2008, 07:49 pm »
Jim,
    What is the best way to get this cutout?  Do they make a rectangular punch that would be a perfect fit?  If not, use a regular knockout punch and file the sides?  Use a dremel?
Dan
randytsuch
Re: IEC cutout for Cornet2
« Reply #1 on: 23 Mar 2008, 08:01 pm »
I use the biggest drill bit I have to start, and get as much out as I can this way.
After that, I use a nibbler to take out the rest.  I usually am not patient enough, and take out a little too much, so you can see it.
But, IEC's are forgiving, they have a plastic edge that hides most of your mistakes.
You can make a pretty bad looking cutout, but it will look fine with the IEC installed.
Randy
hagtech
« Reply #2 on: 24 Mar 2008, 02:59 am »
I do it the hard way.  Small drill bit, perf around the edges with a hundred holes.  Then clippers to break remaining dingleberries.  Middle falls out.  Then use a rough metal file by hand to clean up edge.  It actually can give very good results.
jh
