ok, stupid tube question
0 Members and 1 Guest are viewing this topic. Read 1033 times.
beat
« on: 11 Oct 2003, 02:13 am »
Hello all,
If your amp has 4 el34 tubes and suppose one went bad, do you need to replace all 4? I'm learning..
BTW, if one tends to light up like a gas powered light bulb and causes your power fuse to blow you could assume the tube is bad, right
markC
« Reply #1 on: 11 Oct 2003, 01:37 pm »
It sounds like that tube may have a short, but I would measure the voltage at the tube socket to make sure nothing upstream has gone wrong.
