Osage Audio Products Launches New Listener Select Brand
0 Members and 1 Guest are viewing this topic. Read 1190 times.
osageaudioproducts
    • Osage Audio Products
Osage Audio Products, LLC is proud to announce the introduction of the first two products under the new house brand, Listener Select.
The Listener Select Record Cleaning Brush is handcrafted with a solid cherry handle and specially formulated anti-microbial nylon bristles, and features the Osage logo branded into the handle.  The brush is available in sizes for 12 inch, 10 inch, and 7 inch records and complete instructions are supplied.  This brush is designed with our record cleaning methodology in mind and is a perfect match for any record cleaning fluid, including the award-winning Audio Intelligent Vinyl Solutions products.
The Listener Select Optical Disc Cleaner is a pure, non-residue cleaner designed specifically for use on CD's, SACD's, HDCD's, DVD's, DVD-A's, data discs and all optical grade polycarbonate surfaces.  This product is very effective at removing the residue left by the gasses created in the manufacturing process of the disc as well as other contaminants.  This is not a treatment, but a pure and effective cleaner.  The cleaner is supplied in an attractive green bottle with a fine mist atomizer and a 3M microfiber cloth that is a full 12 inches by 14 inches.  The cleaner is supplied in a long lasting 4 ounce size, not the 2 ounces of other brands, making this the best disc cleaning value on the market.
For more information on Listener Select products, go to: www.osageaudio.com/select.htm.  You may also call 573-696-3551 or email [email protected] for more information or to place an order.  These products can also be ordered through our Online Store.  Please go to www.osageaudio.com and select our Online Store link.
Jim Pendleton
