Audio Intelligent Vinyl Solutions Awarded SoundStage! Reviewers' Choice
0 Members and 1 Guest are viewing this topic. Read 958 times.
osageaudioproducts
    • Osage Audio Products
"The AIVS fluids produced vinyl that was visually and aurally as clean as it could get, often restoring the inky-black luster of the LPs as well. I did think the results were slightly better than with the Walker Prelude system. The AIVS fluids are clearly more economical, and you will spend less time using them and more time listening.  I plan to use these AIVS products from this point forward, which makes them literally a Reviewers' Choice.” –Marc Mickelson, Soundstage!, January 2008.
Buy online at www.audiointelligent.com or check our links page for a retailer near you.  Also, be sure to check out our new Listener Select record cleaning brushes and optical disc cleaner, as well as the new Audio Elegance accessory line and the highly regarded NSR Sonic Reasearch Loudspeakers.
Call 573-696-3551 or email [email protected].
Jim Pendleton
Osage Audio Products, LLC
