0 Members and 1 Guest are viewing this topic. Read 6787 times.
So backing up WAV files you also need to back up the CUE sheet? Why are WAV files any different from lets say a .DOC? If I have a Miles Davis folder, with Kind of Blue subfolder and Blue in Green as one file in that folder, can't this be copied as is? - Or I guess it's that this folder structure isn't where Slimserver gets it's info from? Where does the info come from that Slim uses to search etc?Thanks-Mike
Doesn't the Squeezebox software have some kind of rescan thingy? Seems like if you move your Kind of Blue to a different drive and rescan, that the SBox would now be able to find it OK?Thanks for being patient, I really appreciate it.-Mike
So back to my first question - What info can be included in a FLAC tag that comes in handy, that cannot be captured and associated with a WAV file.All I need is for Slimserver to be able to find a certain track, or album, or artist when I tell it to.Seems like I should be able to do this with WAV.Maybe I have a fundamental misunderstanding of what the tags are used for Thanks
I guess I'm just being a paranoid audiofool about the quality of WAV vs. FLAC - Combined with the cheap storage out there I was thinking to stick with WAV but I see there are good reasons for FLAC. I don't use ripped data for a portable device (I just pop it directly onto my wifes Zen from the CDs), but I guess I might in the future.
Do some folks keep an archival WAV copy and then use the FLAC for daily Squeezeboxing? Pretty silly and redundant I guess?
