Image retention on Plasma TVs
0 Members and 1 Guest are viewing this topic. Read 1269 times.
Norman Tracy
    • Audio Crafters Guild
« on: 20 Mar 2008, 08:06 pm »
BobM
Re: Image retention on Plasma TVs
« Reply #1 on: 21 Mar 2008, 12:53 pm »
Another source for good info:
http://plasmatvbuyingguide.com/
If you're looking for one of the TV's they do a full review on they also give you the proper adjustments to "calibrate" your TV so the picture meets (some) standard - I forget the actual acronym.
I have a plasma and an LCD and I can definitely say I like the plasma better, as long as there's no direct light on it or a reflection of a lamp shining back on me. The resolution is great. The LCD just doesn't cut it for sports either, with any kind of action getting blurred - like a golfer putting, the putter shaft looks jaggedy instead of a straight piece of steel.
Enjoy,
Bob
