0 Members and 1 Guest are viewing this topic. Read 2565 times.
A software update is available for Time Machine (via Software Update), and firmware updates are available for both the Time Capsule and Airport Extreme Base Stations (via Airport Utility v5.3.1). Seems they have added the ability to use Time Machine with a USB-connected hard drive to the AEBS, as well as a few other bug-fixes. From reviews I've read, only attempt to do a Time Machine backup from scratch using this new configuration, as it will not recognize existing backup files.
<<<<<<<"bitter complaints I have with the AEBS."
<<<<<<<"bitter complaints I have with the AEBS."So can anyone confirm whether the firm ware for the AEBS is a new release today and address the hard disk dropouts most of have with the usb ports on the aebs. Also any link to the update?
Quote from: kbuzz3 on 20 Mar 2008, 07:32 pm<<<<<<<"bitter complaints I have with the AEBS."Just so there's no misunderstanding, you didn't even enter my mind when I posted, kbuzz. I was actually thinking of the 1-star raters on Mac's website.'Course, you may be one of 'em. [/quotlol---glad for your post!!!
Quote from: Crimson on 20 Mar 2008, 02:02 pmFrom reviews I've read, only attempt to do a Time Machine backup from scratch using this new configuration, as it will not recognize existing backup files.Hello Crimson, as far as you know, would that mean that I should delete the backup file that is on my Time Capsule currently so that Time Machine takes a brand new complete backup of my Macbook? Thanks for your advice on this, I'll download the fix right away
Quote from: Loftprojection on 21 Mar 2008, 05:02 pmQuote from: Crimson on 20 Mar 2008, 02:02 pmFrom reviews I've read, only attempt to do a Time Machine backup from scratch using this new configuration, as it will not recognize existing backup files.Hello Crimson, as far as you know, would that mean that I should delete the backup file that is on my Time Capsule currently so that Time Machine takes a brand new complete backup of my Macbook? Thanks for your advice on this, I'll download the fix right awayThis only applies if you are going to take a hard drive with an existing Time Machine backup and configure it as an Airdisc (attached to the Airport Extreme base station). If you have the room on the drive, I'd leave the old backup on there till you're confident everything is working to your satisfaction.
