Alternative sources for parts (Cornet2)
0 Members and 1 Guest are viewing this topic. Read 1696 times.
Jesuscookies
« on: 17 Mar 2008, 06:06 pm »
I recently purchased a half kit, and ordered all the parts necessary (except case). However, Digi key is back ordered on a few of the Resistors/Capactors for up to a month and a half.
Does anyone else have a source for parts?
I checked Mouser, and they have a few of the parts but they are different brand names. Does it matter if I mix and match resistors and capacitors?
I need
5 Yageo 680 Ohm 1 watt resistors Part # 680W-1-ND
5 Yageo 3.3K Ohm  1 watt resistor Part # 3.3KW-1-ND
5 Nichicon 47uf 450V Capacitor Part # 493-1461-ND
2 Panasonic .1uf 100V Metal Poly Capacitor Part # EF1104-ND
If anyone has a source for these parts, or extras they would be willing to sell let me know.
I can be reached at [email protected]   Take the NOSPAM out of the email. :)
hagtech
    • http://www.hagtech.com
Re: Alternative sources for parts (Cornet2)
« Reply #1 on: 17 Mar 2008, 06:41 pm »
DigiKey has many alternates.  Its just a matter of digging through the catalog.  Try the:
p680w-1
p3.3kw-1
The 493-1461 appears to be in stock.  Most of the time you can just use their online search engine.  Works great to find alternates.  For the 0.1uF I usually use the P4525, but note that is out of stock too.  A search came up with:
P4725
P4593
495-1103
478-3368
495-2465
And quite a few others.
jh
Jesuscookies
« Reply #2 on: 17 Mar 2008, 06:44 pm »
I did not know if it was acceptable to use those alternatives, and I wanted to be sure.
Thanks for the help... :)
