FS: Air Tight ATC-3 Pre-amp
0 Members and 1 Guest are viewing this topic. Read 1429 times.
gelajoy
« on: 17 Mar 2008, 02:04 am »
I'm clearing out some equipment and decided to sell my Air Tight ATC-3 pre-amp. The pre-amp was recently looked over by the Air Tight Service Rep., Tom Tutay, and everything works as it should. Even though the pre-amp is in beautiful condition I rated it an 8/10 because I'm the second owner. I've had the preamp for five years.
The pre-amp uses a pair of 12AU7 tubes and a single 12AT7 tube and has 4 RCA inputs, a monitor input, a rec output, and a pair of stereo outputs: one for the amp and the other for the subwoofer. You can attach a headphone amp that bypasses the volume control and minimizes the circuit path. There is a selector switch, monitor switch, stereo/mono switch, balance switch, volume knob and on/off switch. The pre-amp is hand made and all connections are direct wired.
Some electronic stuff from the web-site:
Air Tight ATC-3 Preamplifier features:
? SRPP line amp with reinforced buffer stage to assure good noise rejection, low output impedance and extended linearity
? Rich power supply featuring quick-recovery diode for high operational speed and low pulse noise
? Single-steel sheet with multi-layer enamel for high rigidity and low noise
? High-quality input/output jacks with detachable mains cord
I'm asking $1395.  This is a lot of pre-amp for the money.
I accept PayPal but the buyer must cover the PayPal fee. Shipping is also the buyer's responsibility. I'm at 78731 and I only ship within the US.
Jeff
[email protected]
