What Other Receivers/Amps Use The Same All Digital Format Like The Panasonic SA-
0 Members and 1 Guest are viewing this topic. Read 1587 times.
cloudbaseracer
I am contemplating getting a Panasonic SA-XR 57 or 700 and have it modified with high grade parts.  I have read mixed reviews on these but many people seem to feel that if ran all digital, they have phenomenal sound.  I am not sure as I have never heard one.  I would like to try this out in conjunction with a front end digital server system into Berhringer/Emerald Physics CS2.  The possibility of being all digital is appealing (in theory at least) so I wonder what options are available from other manufactures that would allow this using the same topology? I see the term digital and/or switching amp stated as Class D but my understanding is that there is a difference between the B&O module amps like a Bel Canto and this Panasonic/Texas Instruments type.
Hopefully someone can point me in the right direction, explain this in understandable layman terms, and offer input on my "system design path'?
For additional reference I am mainly interested in 2 channel audiophile sound and also while also running a signal from my high def Comcast box or Blu-Ray through my speakers watching my Plasma.  Does any of this make sense?
Thanks for the help,
James
Ric Schultz
I know of three people using the Panny receivers with great success.  One person triamps his Apogee speakers, another replaced his modified Marsh amp with a 700 driving his $10,000 Merlin speakers and another runs $27,000 speakers with modified $13,000 Esoteric transport with stock 700......he says 700 noticeably better than 57.
Don't think there are any other fully digital receivers that I would choose over the Pannies.
Basically, the Panny changes the PCM digital input directly to PWM.....whereas most switching amps change analog into PWM.  Keeping it pure digital is way cool.
You will have to modify the Behringer with digital outs to get the full advantage of the Pannies.....you really don't want to use the analog path in the Behringer and the analog ins on the Pannies.....go straight digital.  You can get the digital out board from switch-box.com and install yourself or have one of the modders do it for you.   You would want to change the digital input jack to coax too.  As long as you have a source that has digital input you would be good to go......of course, you could run analog into the behringer and digital out....you could use that with a source that is not as critical and keep the digital coax for your serious source. A couple of 700s or even 57s run this way would be super and relatively inexpensive.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
take a look at TACT audio or Lyngdorf  too
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Hey guys what is the model number for the Panasonic 700????
playntheblues
Never mind I found it.
cloudbaseracer
Ric,
I have one of the switchbox 3x SPDIF on order and will install it into my Behringer crossover as I just received the CS2's speakers.  I am running 2 of the Panasonic XR700 units- one for the highs and one for the lows.  My question is in regards to your statement about changing the digital input to coax.  Can you explain this further?
James
