BP26 Input Sensitivity
0 Members and 1 Guest are viewing this topic. Read 1543 times.
ashtarul
« on: 15 Mar 2008, 01:45 am »
Hi. I've a DAC (Lavry DA10) which has an adjustable volume control and this is connected to the balanced input of the BP26. I asked them in their forum what would be the correct volume setting to set when connected to the BP26 which has a balanced input sensitivity of 1V (according to the BP26 manual). Now they've come back with a question of their own which is, what is the "absolute maximum input level" specification in "dBu, Volts RMs, or Volts Peak-to-Peak (P-P)"? Anybody with the answer?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP26 Input Sensitivity
« Reply #1 on: 15 Mar 2008, 12:34 pm »
Hi There,
I don't think the input level matters as the BP26 has the volume control before the gain stage - I will check with the designer.
james
« Last Edit: 16 Mar 2008, 11:26 am by James Tanner »
« Reply #2 on: 17 Mar 2008, 02:54 pm »
Hi There,
james
Answer from Stuart Taylor:
15Vrms bal input for 1% distortion at the "to recorder' output
james
ashtarul
« Reply #3 on: 18 Mar 2008, 08:31 am »
Thanks james & stuart
