xlr cables in y-configuration??
0 Members and 1 Guest are viewing this topic. Read 2052 times.
alexone
« on: 13 Mar 2008, 08:17 am »
james,
there was a discussion a while ago about xlr cables to be used as y- cables.
let's say the balanced outs of bp 26 and sp2 are connected with this kind of cable to fit any sst amp's xlr ins.
i've never seen it before anywhere.
- is this possible at all?
- if yes, is it safe??
alex.
  • The Demo is Everything!
    • http://www.bryston.com
Re: xlr cables in y-configuration??
« Reply #1 on: 13 Mar 2008, 02:45 pm »
james,
alex.
Hi James;
   Thanks for forwarding this.  I'm not sure what the customer is asking.  Does he want to Y the connections from a preamp and suround processor? Or does he want to drive two amps with one output?  Thanks.
cwr
alexone
« Reply #2 on: 13 Mar 2008, 03:18 pm »
james,
yes. one preamp + one processor into one amp.
alex
brucek
« Reply #3 on: 13 Mar 2008, 03:51 pm »
Certainly not.
What you propose is shorting the outputs of two line drivers together. Not allowed.
You may only Y-split (a single low impedance) output to multiple (high impedance) inputs.. :)
brucek
