Integrity of old files
0 Members and 1 Guest are viewing this topic. Read 1727 times.
pardales
« on: 9 Mar 2008, 04:34 pm »
Is there a way to check your files to see if they are sound? I started ripping my collection back in the Spring of 05 and now have about 300GB worth of files in ALAC. I would like to know that they are okay. Thanks,
Crimson
« Reply #1 on: 9 Mar 2008, 05:07 pm »
I've heard of stories where file integrity was compromised when performing large batch conversions from one format to another. Other than that I wouldn't be concerned. Some of my files are five years old and have been moved/archived/restored to different drives numerous times over the years and still play absolutely fine.
pardales
« Reply #2 on: 9 Mar 2008, 06:30 pm »
Thank you, Crimson. I did do a large batch file conversion once (ALAC to AAC for my iPod). But I did that with my back-up drive and have since replaced that back-up with my original files. I now have my AAC files on a different computer.
When backing up, is there anything wrong simply dragging your iTunes music folder (with all my ALAC files) over to the new back-up drive? The Wavelength audio website recommends against this, but I don't understand why.
Sorry if this is ancillary to this thread.
Crimson
Re: Integrity of old files
« Reply #3 on: 9 Mar 2008, 09:59 pm »
I remember reading that at their website, and recall it had to do more with expanding your iTunes library than for backup purposes. I will comment, though, that your best bet for backing up files is using a program that automates the process based on specific folders, file verification, and can handle increments. It's easier and safer.
chosenhandle
« Reply #4 on: 10 Mar 2008, 02:14 pm »
disk utility has a "check integrity" option, I believe. I haven't used it, but I have seen it when playing around with drives
zacster
« Reply #5 on: 11 Mar 2008, 05:40 pm »
Use Time Machine.  You never have to touch it once you turn it on.
