AVP-17 and a headphone amp?
0 Members and 1 Guest are viewing this topic. Read 1869 times.
DigitalLF
« on: 5 Mar 2008, 11:51 am »
is there a way to connect a headphone amp to the AVP-17?
(i will use my future AVP-17 as a 2.0 preamp)
plivac
Re: AVP-17 and a headphone amp?
« Reply #1 on: 5 Mar 2008, 07:35 pm »
I use the MIX OUT with analogs. You can also use the R/L w/ bypass ON on the regular analogs if you have them connected via XLR.
DigitalLF
« Reply #2 on: 5 Mar 2008, 09:51 pm »
so MIX OUT with a analog connection to the headphone amp will work? i will buy a AVP-17 within a month or so hopefully so im just getting everything sorted out before the buy :)
is it a button to press to change between R/L output and the MIXOUT output? or is it a change in settings everytime?
i have never ever seen the avp-17 more then basic usage nothing about settings or stuff like that...
plivac
« Reply #3 on: 6 Mar 2008, 03:12 pm »
you don't have to do anything its constant feed so just turn of the amp when you don't want sound coming out.
enjoy it - it sounds great - and get their MultiChannel AMP if you don't have one...
DigitalLF
« Reply #4 on: 6 Mar 2008, 08:37 pm »
i already got ref8 and in the future i will upgrade them to v2 but avp-17 to start with
thank you for your help about MIXOUT :)
closed thread :)
