LRC trim pots
0 Members and 1 Guest are viewing this topic. Read 1615 times.
bigbang
LRC trim pots
« on: 4 Mar 2008, 11:51 pm »
Hello all,
Long time VMPS fan (anyone remeber the supertower), 1st time owner.
Received a LRC today. FST and magawoofs.
The mid trim pot appears to be recessed in further than the tweeter pot and has no retaining nut. Is this normal, or has this unit been violated? Appears to be a small amount of silicone around it as well as that side of the rear plate with the binding posts.
Otherwise this unit appears as new.
Initial listening has me pretty stoked. :D
Brian Cheney
    • http://www.vmpsaudio.com
Re: LRC trim pots
« Reply #1 on: 4 Mar 2008, 11:57 pm »
Nope, for a while some of the large pots we used were available only with short shafts, and they were glued in place.  No problem.  Start with the settings of the screwdriver shafts at around 2 o'clock.
bigbang
Re: LRC trim pots
« Reply #2 on: 5 Mar 2008, 12:57 am »
That's good to hear. And from you, an honor as well!
John Casler
Re: LRC trim pots
« Reply #3 on: 5 Mar 2008, 03:28 am »
Big Bang, welcome to the VMPS Club.
Strangely enough you will see Big B, here pretty much on a daily basis.
Glad to have you aboard.
