0 Members and 1 Guest are viewing this topic. Read 1745 times.
Randy,Thank you very much! I'm going to give it a try the way you suggest (red and yellow sub wires to L/H and R/H black speaker outputs and black sub wire to R/H red speaker output). The subs do have phase switches, so I'll see if changing those afterwards sounds better too.Thanks again.
Randy,Thanks again. I believe I hooked it up the way you've described. The F3's speaker outputs are Red (+) which is ground and Black (-) which is live. So, yellow and red sub wires to black F3 outputs and black sub wire to red F3 output is how I have it.There we no sparks or smoke, and the subs are playing, so can I assume all is well?I did switch the phase on the subs as well.Sorry to be so dense, and if you see anything here that looks wrong, please do let me know!JamesHi James,No, that sounds right. From the previous reply, I was not sure, but what you just said is right. And it works, which is the acid test .As for phase, you just need to play with it a little, and see what sounds better. It depends on the distance from you to the sub.Randy
