0 Members and 1 Guest are viewing this topic. Read 6912 times.
Alloysoft markets "Signal" as a controller for iTunes and Windows Media. It lets you log onto your wifi network and then scroll through your iTunes library. $30 and it works just fine on my Mac.
Hi All,Thanks for the input. I had originally decided to get the Classic, but the more I thought about it (and that discount on the software ) I changed my order to the Touch.Apple is running some pretty good deals right now on the iPods on their refurbished site, BTW. How does the Signal software get istalled? Does it go on the iPod or my PC?Nels
I use a custom skin on my ipod touch as a remote control for my Transporter and Squeezebox, it works great!! I can post the link if anybody is interested?
Am I understanding this right? I have a Powerbook G4 hooked up to my DAC via USB. This set-up happens to be in a different room than my speakers. With the Touch, and the software mentioned above, I can use the Touch as a wireless remote to control my iTunes? If so, COOL!Thanks for your help,
Can I use an Ipod Touch to run Signal to control Foobar200 running on my Vista Notebook ? Thanks
Signal vs Remote Buddy?
Makes sense. Try both. I don't currently use iTunes for volume so really am only looking to be able to control my selection of album/song. If I am planning on only using the iTouch as a remote, and not primarily as in iPod, then I should be okay with the 8GB version? I have a 80B video iPod as well. Thank you,
