difference 25-BPS - 25-BP
0 Members and 1 Guest are viewing this topic. Read 1891 times.
Gogo
« on: 28 Feb 2008, 03:12 pm »
Hello to everybody,
what is the between these two generations of this beautiful preamp?
Thanks for any information...
Gogo
  • The Demo is Everything!
    • http://www.bryston.com
Re: difference 25-BPS - 25-BP
« Reply #1 on: 28 Feb 2008, 03:43 pm »
Hello to everybody,
Gogo
Not sure what these are?
james
Gogo
« Reply #2 on: 28 Feb 2008, 04:05 pm »
Was the new name changed only because of the introduction of the silver faceplate?
« Reply #3 on: 28 Feb 2008, 04:26 pm »
No.
The only thing I can think of is that our German distributor used slightly different names in Germany for the preamps.
james
mv038856
« Reply #4 on: 29 Feb 2008, 04:48 pm »
Hi James, hi everybody!
No.
james
James, you are right. Sun Audio, the German distributor, introduced the BPS-labelling to distinguish an improved version of the BP 25 (we both know that they are very creative in (re-)labelling...  :wink:). It was the shift from the BP-PSR to the MPS-1 as the external power supply and some improvements on the components inside. I got my BP-25 upgraded at Sun Audio and was able to acquire a MPS-1 (in Australia) to make my BP-25 a so-called BPS-25.
How would you comment on the changes on the BP-25?
Comparing the two power supplies, the MPS-1 makes a better impression than the BP-PSR, only beaten by the MPS-2 that's part of the BP-26.
I hope this helps.
Cheers!
Markus
