OK after all, what is the best sounding SB3 firmware now ? Still 15 or newer ?
0 Members and 1 Guest are viewing this topic. Read 1625 times.
oris98
Hi all,
After so many firmware upgrade for the SB3, is firmware 15 still sound the best for audiophiles ?  I used to use 15 but after upgraded to the lastest version of Slimserver, it automatically upgraded to firmware level 81 and it sounds pretty good.  Any comment ?  What fireware are you using ?  and why ?     I am using RWA digital modded SB3.
Thanks.
darrenyeats
I believe there were some "problem" firmware levels but these are long in the past AFAIK.
Darren
mcgsxr
I stuck with 15 for a long time, but have updated to the current, and am sticking with it.  I like the 100 steps of volume, and like what I hear.  I have Bolder modded unit.
