High Value Speaker Wire Recommendations Please...
0 Members and 1 Guest are viewing this topic. Read 1938 times.
Doublej
« on: 26 Feb 2008, 09:35 pm »
A friend is wiring one of the rooms in his house for home theater.  What high value wire should I recommend for an in-wall install?
« Last Edit: 27 Feb 2008, 02:41 am by Doublej »
Toka
Re: High Speaker Wire Recommendations Please...
« Reply #1 on: 26 Feb 2008, 11:11 pm »
Heavy gauge (12 or 10 AWG) and plenum rated...whatever you can find.
WGH
« Reply #2 on: 27 Feb 2008, 12:50 am »
Monoprice has great CL2 rated cables if you are not running through plenums
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
Blue Jeans cables if your friend has deep pockets
Rating guide
http://www.bluejeanscable.com/articles/inwallrating.htm
jmc207
« Reply #3 on: 27 Feb 2008, 01:21 am »
I've found the Audioquest FLX 14/4 to be a smooth, detailed cable, and quite a bargain considering the performance.
http://www.onecall.com/ProductDetails.aspx?id=88213
The Kimber KWIK-12 seems to have a bit more bass but is not as open sounding.
http://www.audioadvisor.com/prodinfo.asp?number=KKKWIK
The Monster Cable S144RCL did a decent job from the midrange on up, but for some reason, didn't seem to deliver any bass in my system. Weird!
http://www.onecall.com/ProductDetails.aspx?id=10807
YMMV, and probably will, but those are my experiences over several months with the same set of speakers and electronics. I was really surprised by the differences since the construction is so similar. I need a life! :-)
Doublej
« Reply #4 on: 27 Feb 2008, 07:43 pm »
Dumb question on the Audioquest. I take it you tie two wires together for + and two for -. Does it matter which ones?
jmc207
Re: High Value Speaker Wire Recommendations Please...
« Reply #5 on: 27 Feb 2008, 07:54 pm »
Yes, take a wire and pair it with the one opposite it for each positive and negative run. If you look at the picture on the Onecall site it would be the black/blue and red/white together. From what I've read that's how most of these 4 wire cables are to be connected. If you tie adjacent wires together it will change the electrical parameters a bit, I think rolling off the highs a touch.
