Moom LP3 ... CIAudio VPP-1
0 Members and 1 Guest are viewing this topic. Read 2345 times.
USAudio
« on: 24 Feb 2008, 07:48 pm »
The new Moon LP3 Phono Preamp looks suspiciously familiar ... cosmetically ...
http://www.simaudio.com/moonlp3.htm
... to the CIAudio VPP-1:
http://www.ciaudio.com/vpp1.html
doesn't it?
Must be the same chassis supplier...?   :scratch:
SatoriGFX
Re: Moom LP3 ... CIAudio VPP-1
« Reply #1 on: 27 Feb 2008, 03:15 am »
doesn't it?
They are both budget pieces.  I would not be surprised if the chassis supplier was the same.  Having said that, they do not have the same dimensions according to their respective web pages.  One runs on 12V the other 14V.  One has gain settings of 40 and 50 the other of 40 and 60.  They aren't the same phono stage (though I guess it's possible that Simaudio contracted someone to design it for them, though unlikely).  At that price point, I am not surprised.  Do you want to pay for fancy casework or performance?
