0 Members and 1 Guest are viewing this topic. Read 3592 times.
I'd have to see a schematic before I'd make any suggestions. I, personally, feel that upgrades are best done yourself, so you can do one at a time and evaluate. Tedious but more systematic. What I've read about undervolting heaters (what having 12V on a 12.6V heater is) is usually positive in favor of the lower voltage (slightly lower, not a lot lower). It usually means the tube runs a bit quieter and sometimes you get a tiny bit of distortion reduction too, but not always. It can be a bit tube specific though. The GGP uses 12au7's? Well if I had a schematic I could make some suggestions of things to try, but there would be no gaurantee they would result in better sonics. However, there is usually enough chatter about good results to make me suggest trying them.
The GG responds well to better output coupling caps. Jensen PIO bypassed with a Sonicap Platinum sounded very good to me. I've recently become a fan of the Obbligato caps (diyhifisupply.com in Hong Kong), I suspect they would work well in the GG. It's not real picky about tubes but it did sound very nice with some NOS Mullard's. The volume control pot does need to be replaced IMO but you're already doing that. BR is a fan of zener diodes for voltage regulation and I'm pretty sure he uses them for both HV and filament circuits but I'd have to look at the schematic to be sure. If I think about I'll look tonight. The schematic is published in his book "Audio Reality", which he sells on his site.I also put in some fast/quiet diodes in the PS and added some bypass caps to the PS as well. You can also change the feedback resistors in order to change the gain (about 12dB IIRC) or to give it a "tubey" sound. The GG does not have the "typical" tube sound of warm and perhaps syrupy. The feedback values are also discussed the Audio Reality chapter on the GG.mike
I think the 5751's are 12ax7 equivalents, iirc. That would be way too much gain for a preamp.
Well, I have thought about those feedback resistors. Not sure I'm even gonna touch them. As far as tubes go, I've been told that the Cleartops RCA are good and reasonably cheap. So what caps did you use for the bypassing and what diodes did you use? Was thinking about some hexfred There are 6 22uF caps on the supply board, and 3 22uF on the audio board. Not sure what those three do, but don't want to do anything that's gonna change freq response. There was one guy who said changing the heaters to 12.6 actually opened up the sound more. Don't know about that one. That would take some mod of the regulation circuit on the GGP. If I go that route, I might as well get the CCS boards from Bottlehead. People seem to think the 12BH7 is a better tube than the 12AU7. It does I'm told require a modification of the heater pin replacement, but that's also a slight possibility. At this point, I'm just interested in upgrading the present parts to better ones. Maybe, get some 5751, or some 5814 tubes. Any comments? I don't know if those 3 caps are coupling caps between stages. To bad, those just can't be removed.
