How to reduce output from Class-A tube amp?
0 Members and 1 Guest are viewing this topic. Read 2324 times.
lo mein
« on: 6 Oct 2003, 05:19 pm »
How can I reduce the output of Class-A tube amp (guitar amp) to 1 watt (one watt) or less?
Thanks.
Curt
« Reply #1 on: 6 Oct 2003, 05:36 pm »
Reduce the input  :D That's an easy solution.
Use a voltage divider on the input (two metal film resistors) or even a pot (easy to adjust) since it's just mono.
lo mein
« Reply #2 on: 6 Oct 2003, 07:25 pm »
Quote from: Curt
Thanks for the quick tip. Curt.
But can you be more specific, like exactly what parts, value, to use, etc. Maybe even a wiring diagram.
The amp that I want to reduce the power is the Vox AC-15. I do have the schematic already.
I want to be able to get full power tube compression sound but without the loud noise. Even 1 watt is loud when driving a 4x12 cab.
Thanks again.
Curt
« Reply #3 on: 6 Oct 2003, 08:25 pm »
You have an e-mail with a schematic. It was easier than linking to my server.
lo mein
« Reply #4 on: 6 Oct 2003, 09:39 pm »
Quote from: Curt
Got it. You're DA MAN! Curt. Thanks. Best of all. I don't even have to butcher the amp. :)
Thanks.
biggerdog
« Reply #5 on: 8 Oct 2003, 02:05 pm »
That method will not run the amp into the power compression region you are seeking, it will simply reduce the level, just like turning down the volume control.
You'll need a couple of high power resistors.  The values will depend on the speaker impedence, and the amp's power output at clipping.
Can you supply this info?
lo mein
« Reply #6 on: 10 Oct 2003, 12:56 am »
Quote from: biggerdog
Curt's method works. I wired it just  before the amp's output to speaker's terminal.
The amp is a Vox AC15(Not reissue.) The speaker is 8 ohms. I believe.
I'll experiment with different ways as well. I do have a couple more amps to doctor. As I do run everything in stereo.  Need only about 0.5 watt for recording.
And I don't like to play loud anymore at home.
Thanks.
Curt
« Reply #7 on: 10 Oct 2003, 07:50 am »
The circuit I sent was to go between the source (instrument) and the amplifier, not between the amp and the speaker :o
biggerdog
« Reply #8 on: 10 Oct 2003, 10:47 am »
Ooh!  I don't know exactly what ciruit diagram Curt sent you, but if you're using metal film resistors or a volume pot between amp output and speaker, it probably won't last very long.
biggerdog
Forgot to say...
« Reply #9 on: 10 Oct 2003, 10:54 am »
Also, with tube amps, you're supposed to keep the output loaded down with something close to a speaker's impedance.  If you don't it's possible (when you crank it) that the output transformer or tubes will arc internally, from excessive voltage.
