JBL 2404H, UHF transducer pair
0 Members and 1 Guest are viewing this topic. Read 1245 times.
jlharden
« on: 22 Feb 2008, 01:09 am »
http://www.jblpro.com/pages/pub/components/2404.pdf
Designed for use as an ultra-high frequency driver in multi-element, wide range loudspeaker systems, the JBL Model 2404H delivers an unmatched combination of wide, tightly controlled dispersion, extended frequency response, high power capacity, and high efficiency.
Bi-Radial® constant coverage horn design
100° x 100° dispersion from 3 kHz to 20 kHz
40 watts continuous program power handling
8 ohm impedance
3 kHz to 21.5 kHz response
44 mm (1 3/4 in) edgewound aluminum voice coil
105 dB sensitivity, 1 W@ 1 m (3.3 ft)
These are from a previous build and should be getting used! I purchased this pair from http://www.jamminjersey.com/speakers.php?prod=jblcomp#Tweeters tested and reportedly in "excellent" condition. I'm pretty particular(obsessive?) and will call them very good condition. I paid way too much at $350 for the pair. Looking for $275+shipping from 61910
email: [email protected] with any questions or for more pics.
