XLR Shorting Plug
0 Members and 1 Guest are viewing this topic. Read 1817 times.
schodge
XLR Shorting Plug
« on: 21 Feb 2008, 10:13 pm »
Most of what I've found on the web regarding creating XLR shorting plugs (to try and reduce noise picked up through unused inputs - worth a shot) shorts only hot to ground, and not negative as well.  Is there a reason for this?
With my RCA shorting plugs, I "shorted" using a 1k resistor - partly because I was worried they might get unintentionally stuck into an output and fry an output stage, and partly for a reason that I thought was quite good but I can't currently remember.  Given that the first is impossible for XLRs, is there a good reason to use resistors instead of straight shorts?
Shayne Hodge
